Device: Startup Trigger
The Device: Startup Trigger fires a workflow whenever the Gateway Edge Agent starts or restarts.
Device Startup Trigger
The Device: Startup Trigger has no configuration. When a workflow with this trigger is deployed to an Edge Compute Device, the workflow will fire every time the Gateway Edge Agent starts or restarts.
The payload contains an empty object on the standard data field, since there is no information to report other than that the agent started or restarted.
In the general case, a Device: Startup workflow payload looks like the following:
"agentEnvironment": {
"EXAMPLE": "Environment Variable"
"agentVersion": "1.31.0",
"applicationId": "555555555555eeeeeeeeeeee",
"applicationName": "My Great Application",
"data": {},
"device": {
"attributes": {
"exampleNumber": {
"attributeTags": {
"attrTagKey": "tagValue1"
"dataType": "number",
"name": "exampleNumber"
"exampleString": {
"attributeTags": {
"attrTagKey": "tagValue2"
"dataType": "string",
"name": "exampleString"
"creationDate": "2018-03-16T18:19:03.376Z",
"deviceClass": "edgeCompute",
"deviceId": "222222222222bbbbbbbbbbbb",
"id": "222222222222bbbbbbbbbbbb",
"name": "My Great Device",
"tags": {
"aTagKey": [
"exampleTagValue"
"tagWithMultipleValues": [
"tagValue",
"anotherTagValue"
"deviceName": "My Great Device",
"deviceTags": {
"aTagKey": [
"exampleTagValue"
"tagValue",
"anotherTagValue"
"flowId": "333333333333cccccccccccc",
"flowName": "My Great Workflow",
"flowVersion": "myFlowVersion",
"globals": {
"aJsonGlobal": {
"key": "value"
"aNumberGlobal": 42,
"aStringGlobal": "My value"
"isConnectedToLosant": false,
"triggerId": "<trigger key>",
"triggerType": "onBoot"
