Application Job Log Actions
https://api.losant.com/applications/APPLICATION_ID/jobLogs/JOB_ID
Below are the various requests that can be performed against the Application Job Log resource, as well as the expected parameters and the potential responses.
Returns the job log for the given ID
GET https://api.losant.com/applications/APPLICATION_ID/jobLogs/JOB_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationJobLog.*, or applicationJobLog.get.
JOB_IDID associated with the job execution575ec8687ae143cd83dc4a98
CodeTypeDescription
200Application Job LogAn application job log
CodeTypeDescription
404ErrorError if application job log was not found
Application Job Log
Schema for a single Application Job Log
Application Job Log Schema
  • {} 3 keys
    • "object"
    • {} 19 keys
      • {} 2 keys
        • {} 2 keys
          • {} 2 keys
            • {} 1 key
              • {} 2 keys
                • {} 2 keys
                  • {} 2 keys
                    • {} 2 keys
                      • {} 2 keys
                        • {} 2 keys
                          • {} 2 keys
                            • {} 2 keys
                              • {} 2 keys
                                • {} 2 keys
                                  • {} 2 keys
                                    • {} 2 keys
                                      • {} 2 keys
                                        • {} 11 keys
                                          • {} 20 keys
                                        Application Job Log Example
                                        • {} 9 keys
                                          • "575ec76c7ae143cd83dc4a96"
                                          • "575ec8687ae143cd83dc4a97"
                                          • "application"
                                          • "2025-06-10T04:00:00.000Z"
                                          • "2025-06-10T04:00:01.000Z"
                                          • "inProgress"
                                          • "ArchiveData"
                                          • {} 2 keys
                                          • {} 3 keys
                                            • "object"
                                            • {} 2 keys
                                              • {} 1 key
                                                • {} 1 key
                                              • {} 2 keys
                                                • "NotFound"
                                                • "Application was not found"
