Experience Group Actions#
https://api.losant.com/applications/APPLICATION_ID/experience/groups/EXPERIENCE_GROUP_ID
Below are the various requests that can be performed against the Experience Group resource, as well as the expected parameters and the potential responses.
Delete#
Deletes an experience group
Method And Url #
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/groups/EXPERIENCE_GROUP_ID
Authentication #
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceGroup.*, or experienceGroup.delete.
Request Path Components #
APPLICATION_ID ID associated with the application 575ec8687ae143cd83dc4a97
EXPERIENCE_GROUP_ID ID associated with the experience group 575ed78e7ae143cd83dc4aab
Request Headers #
Name Required Description Default
Curl Example #
Successful Responses #
Code Type Description
200 Success If experience group was successfully deleted
Error Responses #
404 Error Error if experience group was not found
Get#
Retrieves information on an experience group
Method And Url #
GET https://api.losant.com/applications/APPLICATION_ID/experience/groups/EXPERIENCE_GROUP_ID
Authentication #
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceGroup.*, or experienceGroup.get.
Request Headers #
Curl Example #
200 Experience Group Experience group information
Error Responses #
Patch#
Updates information about an experience group
Method And Url #
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/groups/EXPERIENCE_GROUP_ID
Authentication #
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceGroup.*, or experienceGroup.patch.
Request Headers #
Request Body #
The body of the request should be serialized JSON that validates against the Experience Group Patch schema. For example, the following would be a valid body for this request:
  "name": "My New Group Name",
  "experienceUserIds": [
    "575ed70c7ae143cd83dc4aa9",
    "675ed70c7ae143cd83dc4aa9"
  "experienceEndpointIds": [
    "58b9d743cbfafe1be675744b",
    "58b9d743cbfafe1be675744c"
Curl Example #
    -d '{"name":"My New Group Name","experienceUserIds":["575ed70c7ae143cd83dc4aa9","675ed70c7ae143cd83dc4aa9"],"experienceEndpointIds":["58b9d743cbfafe1be675744b","58b9d743cbfafe1be675744c"]}' \
200 Experience Group Updated experience group information
Error Responses #
