Edge 1.11.0
Device: Startup Trigger Node
The Device: Startup Trigger will trigger a workflow whenever the Losant Edge Agent starts or restarts.
Device Startup Trigger
This node does not have any properties. Any edge device that has an edge workflow with this trigger will fire on edge agent startup or whenever the agent restarts.
The payload will have an empty object on the standard data field, since there is no useful data to report other than the fact the device started. In the general case, a device startup workflow payload will look like the following:
  "time": <time of startup>,
  "triggerId": <id of the triggering device>,
  "triggerType": "onBoot",
  "deviceTags": {<any tags for the device>},
  "deviceName": <the device name>,
  "globals": <object of workflow globals>
For the example workflow above, a specific payload for a triggered workflow might look like this:
  "applicationName": "Embree",
  "deviceTags": {
    "floor": ["2"],
    "location": ["warehouse1"]
  "flowName": "Connection Info",
  "globals": {}
