Device: Delete Node#
The Delete Device Node allows a workflow to remove a Device inside the current application.
Delete Device Node
Configuration#
To find the device to delete, the node requires the device ID. This field is templatable, and so supports finding a device based on the current workflow payload.
This node can only delete one device at a time, so the return value from the template must be a single device ID.
Delete Device Node Configuration
Optionally you can provide a payload path in the "Result Path" field so that the delete device result can be placed at that path on the current workflow payload. In the case of a successful device deletion, this will be true, and in the case of a failed device deletion this will be an object of any errors about the deletion of the device.
Delete Device Node Result
For instance, given the example node configuration in the screenshots above, this is a possible result for a successful device deletion:
    "deviceId": "589de7d2a1975a00017b227f",
    "losantDevice": true
