Experience Versions Actions
https://api.losant.com/applications/APPLICATION_ID/experience/versions
Below are the various requests that can be performed against the Experience Versions resource, as well as the expected parameters and the potential responses.
Returns the experience versions for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/versions
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, experienceVersions.*, or experienceVersions.get.
APPLICATION_ID ID associated with the application 575ec8687ae143cd83dc4a97
Name Required Description Default Example
sortField N Field to sort the results by. Accepted values are: version, id, creationDate, lastUpdated version sortField=version
sortDirection N Direction to sort the results by. Accepted values are: asc, desc asc sortDirection=asc
page N Which page of results to return 0 page=0
perPage N How many items to return per page 100 perPage=10
filterField N Field to filter the results by. Blank or not provided means no filtering. Accepted values are: version filterField=email
filter N Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. filter=my*version
Code Type Description
200 Experience Versions Collection of experience versions
404 Error Error if application was not found
Create a new experience version for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/versions
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, experienceVersions.*, or experienceVersions.post.
The body of the request should be serialized JSON that validates against the Experience Version Post schema. For example, the following would be a valid body for this request:
  "version": "myNewVersion",
  "description": "my version description",
  "domainIds": [
    "58c1de6c8f812590d8e82980"
  "slugIds": [
    "5b995e51ea9994b50d745284"
    -d '{"version":"myNewVersion","description":"my version description","domainIds":["58c1de6c8f812590d8e82980"],"slugIds":["5b995e51ea9994b50d745284"]}' \
201 Experience Version Successfully created experience version
