Experience Slug Actions
https://api.losant.com/applications/APPLICATION_ID/experience/slugs/EXPERIENCE_SLUG_ID
Below are the various requests that can be performed against the Experience Slug resource, as well as the expected parameters and the potential responses.
Delete
Deletes an experience slug
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/slugs/EXPERIENCE_SLUG_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceSlug.*, or experienceSlug.delete.
APPLICATION_ID ID associated with the application 575ec8687ae143cd83dc4a97
EXPERIENCESLUGID ID associated with the experience slug 575ed78e7ae143cd83dc4aab
Name Required Description Default
Code Type Description
200 Success If experience slug was successfully deleted
404 Error Error if experience slug was not found
Retrieves information on an experience slug
GET https://api.losant.com/applications/APPLICATION_ID/experience/slugs/EXPERIENCE_SLUG_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceSlug.*, or experienceSlug.get.
200 Experience Slug Experience slug information
Patch
Updates information about an experience slug
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/slugs/EXPERIENCE_SLUG_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceSlug.*, or experienceSlug.patch.
The body of the request should be serialized JSON that validates against the Experience Slug Patch schema. For example, the following would be a valid body for this request:
  "slug": "my-new-slug",
  "version": null
    -d '{"slug":"my-new-slug","version":null}' \
200 Experience Slug Updated experience slug information
