Flow Versions resource, as well as the expected
Returns the flow versions for a flow
GET https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions
A valid api access token is required to access this endpoint. The token must
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersions.*, or flowVersions.get.
Path Component
Description
Example
APPLICATION_ID
ID associated with the application
575ec8687ae143cd83dc4a97
FLOW_ID
ID associated with the flow
575ed18f7ae143cd83dc4aa6
Name
Required
Description
Default
Example
sortField
N
Field to sort the results by. Accepted values are: version, id, creationDate, lastUpdated
version
sortField=version
sortDirection
N
Direction to sort the results by. Accepted values are: asc, desc
asc
sortDirection=asc
page
N
Which page of results to return
0
page=0
perPage
N
How many items to return per page
100
perPage=10
filterField
N
Field to filter the results by. Blank or not provided means no filtering. Accepted values are: version
filterField=version
filter
N
Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.
filter=my*version
includeCustomNodes
N
If the result of the request should also include the details of any custom nodes referenced by the returned workflows
false
includeCustomNodes=true
query
N
Workflow filter JSON object which overrides the filterField and filter parameters. See Advanced Workflow Version Query for more details.
query={”version”:”theVersion”}
Name
Required
Description
Default
Authorization
Y
The token for authenticating the request, prepended with Bearer
POST https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions
all.Application, all.Organization, all.User, flowVersions.*, or flowVersions.post.
Path Component
Description
Example
APPLICATION_ID
FLOW_ID
Name
Required
Description
Default
Example
includeCustomNodes
N
false
allowReplacement
N
Allow replacement of an existing flow version with same version name
false
allowReplacement=true
Name
Required
Description
Default
Authorization
Y
The body of the request should be serialized JSON that validates against
the Workflow Version Post schema. For example, the following would be a
valid body for this request:
{"version":"v1.2.3","notes":"Notes about my new workflow version","enabled":false}
curl -H 'Content-Type: application/json'\
-H 'Accept: application/json'\
-H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN'\
-d '{"version":"v1.2.3","notes":"Notes about my new workflow version","enabled":false}'\
