Resource Job Actions
https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID
Below are the various requests that can be performed against the Resource Job resource, as well as the expected parameters and the potential responses.
Cancel Execution
Marks a specific resource job execution for cancellation
POST https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID/cancelExecution
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, resourceJob.*, or resourceJob.cancelExecution.
APPLICATION_ID ID associated with the application 575ec8687ae143cd83dc4a97
RESOURCEJOBID ID associated with the resource job 575ec8687ae143cd83dc4a97
Name Required Description Default Example
executionId Y The ID of the execution to cancel executionId=632e18632f59592e773a4153
    https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID/cancelExecution?executionId=632e18632f59592e773a4153
Code Type Description
200 Success If the execution was successfully marked for cancellation
404 Error Error if execution was not found
Delete
Deletes a resource job
DELETE https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, resourceJob.*, or resourceJob.delete.
includeWorkflows N If the workflows that trigger from this resource job should also be deleted. includeWorkflows=true
200 Success If resource job was successfully deleted
404 Error Error if resource job was not found
Execute
Queues the execution of a resource job
POST https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID/execute
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, resourceJob.*, or resourceJob.execute.
The body of the request should be serialized JSON that validates against the Resource Job Execution Options schema. For example, the following would be a valid body for this request:
  "templateContext": "{ \"myData\": 123 }"
    -d '{"templateContext":"{ \"myData\": 123 }"}' \
200 Success With Execution ID If the job was successfully queued
Returns a resource job
GET https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, resourceJob.*, or resourceJob.get.
200 Resource Job A single resource job
404 Error Error if application was not found
Logs
Retrieves information on resource job executions
GET https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID/logs
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, resourceJob.*, or resourceJob.logs.
limit N Max log entries to return (ordered by time descending) 1 limit=10
since N Look for log entries since this time (ms since epoch) since=1465790400000
200 Resource Job Execution Logs Resource job execution information
Patch
Update a resource job
PATCH https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, resourceJob.*, or resourceJob.patch.
The body of the request should be serialized JSON that validates against the Resource Job Patch schema. For example, the following would be a valid body for this request:
  "name": "Example Resource Job",
  "queryJson": "{ \"name\": \"my device\"}"
    -d '{"name":"Example Resource Job","queryJson":"{ \"name\": \"my device\"}"}' \
201 Resource Job Successfully updated resource job
