Application Templates Actions
https://api.losant.com/applicationTemplates
Below are the various requests that can be performed against the Application Templates resource, as well as the expected parameters and the potential responses.
Returns the application templates the current user has permission to see
GET https://api.losant.com/applicationTemplates
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.read, applicationTemplates.*, or applicationTemplates.get.
sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated | name | sortField=name |
filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name, authorName | filterField=name | |
filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my * app | |
keywords | N | List of keywords to filter by. Matches all provided keywords. | keywords[0]=gps&keywords[1]=aws | |
categoryId | N | ID of a category to filter by. | categoryId=575ec76c7ae143cd83dc4a96 |
Code | Type | Description |
200 | Application Templates | Collection of application templates |
Get Categories
Returns a category list, beginning at the specified category
GET https://api.losant.com/applicationTemplates/categories
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.read, applicationTemplates.*, or applicationTemplates.getCategories.
baseId | N | ID of the category to begin from | baseId=575ed6e87ae143cd83dc4aa8 |
200 | Application Template Categories | Collection of application categories |
Get Unique Keywords
Returns an array of all unique keywords currently in use by templates
GET https://api.losant.com/applicationTemplates/keywords
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.read, applicationTemplates.*, or applicationTemplates.getUniqueKeywords.
200 | Template Keywords | Array of all unique template keywords |
