Experience Endpoint resource, as well as the expected
A valid api access token is required to access this endpoint. The token must
all.Application, all.Organization, all.User, experienceEndpoint.*, or experienceEndpoint.delete.
Path Component
Description
Example
APPLICATION_ID
ID associated with the application
575ec8687ae143cd83dc4a97
EXPERIENCEENDPOINTID
ID associated with the experience endpoint
575ed78e7ae143cd83dc4aab
Name
Required
Description
Default
Example
includeWorkflows
N
If the workflows that utilize this experience endpoint should also be deleted.
includeWorkflows=true
Name
Required
Description
Default
Authorization
Y
The token for authenticating the request, prepended with Bearer
GET https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/EXPERIENCE_ENDPOINT_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceEndpoint.*, or experienceEndpoint.get.
Path Component
Description
Example
APPLICATION_ID
Name
Required
Description
Default
Example
version
N
Version of this experience endpoint to return
develop
version=develop
Name
Required
Description
Default
Authorization
Y
Retrieves information on resources linked to an experience endpoint
GET https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/EXPERIENCE_ENDPOINT_ID/linkedResources
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceEndpoint.*, or experienceEndpoint.linkedResources.
Path Component
Description
Example
APPLICATION_ID
Name
Required
Description
Default
Example
version
N
Version of this experience endpoint to query
develop
version=develop
includeCustomNodes
N
If the result of the request should also include the details of any custom nodes referenced by returned workflows
false
includeCustomNodes=true
Name
Required
Description
Default
Authorization
Y
all.Application, all.Organization, all.User, experienceEndpoint.*, or experienceEndpoint.patch.
Path Component
Description
Example
APPLICATION_ID
Name
Required
Description
Default
Authorization
Y
The body of the request should be serialized JSON that validates against
the Experience Endpoint Patch schema. For example, the following would be a
valid body for this request:
