Experience View Actions
/experience/views/EXPERIENCE_VIEW_ID
Experience View resource, as well as the expected
Delete
Deletes an experience view
DELETE https://api.losant.com/applications/APPLICATION_ID
A valid api access token is required to access this endpoint. The token must
all.Application, all.Organization, all.User, experienceView.*, or experienceView.delete.
Path Component |
Description |
Example |
APPLICATION_ID |
ID associated with the application |
575ec8687ae143cd83dc4a97 |
EXPERIENCE_VIEW_ID |
ID associated with the experience view |
575ed78e7ae143cd83dc4aab |
Name |
Required |
Description |
Default |
Authorization |
Y |
The token for authenticating the request, prepended with Bearer |
https://api.losant.com/applications/APPLICATION_ID/experience/views/EXPERIENCE_VIEW_ID
Code |
Type |
Description |
200 |
Success |
If experience view was successfully deleted |
Code |
Type |
Description |
400 |
Error |
Error if malformed request |
404 |
Error |
Error if experience view was not found |
Retrieves information on an experience view
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceView.*, or experienceView.get.
Path Component |
Description |
Example |
APPLICATION_ID |
Name |
Required |
Description |
Default |
Example |
version |
N |
Version of this experience view to return |
develop |
version=develop |
Name |
Required |
Description |
Default |
Authorization |
Y |
Code |
Type |
Description |
400 |
Error |
404 |
Error |
Patch
Updates information about an experience view
PATCH https://api.losant.com/applications/APPLICATION_ID
all.Application, all.Organization, all.User, experienceView.*, or experienceView.patch.
Path Component |
Description |
Example |
APPLICATION_ID |
Name |
Required |
Description |
Default |
Authorization |
Y |
The body of the request should be serialized JSON that validates against
the Experience View Patch schema. For example, the following would be a
valid body for this request:
"body": "New Content! <p>{{newData}}</p>",
"viewTags": {
"customKey": "newCustomValue"
-d '{"body":"New Content! <p>{{newData}}</p>","viewTags":{"customKey":"newCustomValue"}}' \
Code |
Type |
Description |
200 |
Experience View |
Updated experience view information |
Code |
Type |
Description |
400 |
Error |
404 |
Error |
