Device Recipes Actions
https://api.losant.com/applications/APPLICATION_ID/device-recipes
Below are the various requests that can be performed against the Device Recipes resource, as well as the expected parameters and the potential responses.
Returns the device recipes for an application
GET https://api.losant.com/applications/APPLICATION_ID/device-recipes
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, deviceRecipes.*, or deviceRecipes.get.
sortFieldNField to sort the results by. Accepted values are: name, id, creationDate, lastUpdatednamesortField=name
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: namefilterField=name
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my * recipe
tagsAsObjectNReturn tags as an object map instead of an arraytagsAsObject=false
attributesAsObjectNReturn attributes as an object map instead of an arrayattributesAsObject=true
CodeTypeDescription
200Device RecipesCollection of device recipes
CodeTypeDescription
Create a new device recipe for an application
POST https://api.losant.com/applications/APPLICATION_ID/device-recipes
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, deviceRecipes.*, or deviceRecipes.post.
The body of the request should be serialized JSON that validates against the Device Recipe Post schema. For example, the following would be a valid body for this request:
"name": "My New Device Recipe",
"deviceName": "Future device name",
"description": "Description of my new device recipe",
"deviceDescription": "Future device description",
"tags": [
"key": "TagKey",
"value": "TagValue"
"attributes": [
"name": "voltage",
"dataType": "number"
"deviceClass": "standalone"
-d '{"name":"My New Device Recipe","deviceName":"Future device name","description":"Description of my new device recipe","deviceDescription":"Future device description","tags":[{"key":"TagKey","value":"TagValue"}],"attributes":[{"name":"voltage","dataType":"number"}],"deviceClass":"standalone"}' \
CodeTypeDescription
201Device RecipeSuccessfully created device recipe
CodeTypeDescription
Device Recipe
Schema for a single Device Recipe
Device Recipe Schema
  • {} 3 keys
    • "object"
    • {} 16 keys
      • {} 2 keys
        • {} 2 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 3 keys
                  • {} 3 keys
                    • {} 2 keys
                      • {} 2 keys
                        • {} 3 keys
                          • {} 3 keys
                            • {} 2 keys
                              • {} 2 keys
                                • {} 1 key
                                  • {} 3 keys
                                    • {} 1 key
                                  Device Recipe Example
                                  • {} 12 keys
                                    • "575ecec57ae143cd83dc4a9f"
                                    • "575ec8687ae143cd83dc4a97"
                                    • "2016-06-13T04:00:00.000Z"
                                    • "Actual recipe name"
                                    • "Future device name"
                                    • "My recipe description"
                                    • "Future device description"
                                    • [] 1 item
                                      • [] 1 item
                                        • "standalone"
                                      Device Recipe Post
                                      Schema for the body of a Device Recipe creation request
                                      Device Recipe Post Schema
                                      • {} 5 keys
                                        • "object"
                                        • {} 11 keys
                                          • {} 3 keys
                                            • {} 3 keys
                                              • {} 2 keys
                                                • {} 2 keys
                                                  • {} 3 keys
                                                    • {} 3 keys
                                                      • {} 2 keys
                                                        • {} 2 keys
                                                          • {} 1 key
                                                            • {} 3 keys
                                                              • {} 1 key
                                                              • false
                                                              • [] 1 item
                                                              Device Recipe Post Example
                                                              • {} 7 keys
        • "My New Device Recipe"
        • "Description of my new device recipe"
        • [] 1 item
        • [] 1 item
        • "standalone"
        Device Recipes
        Schema for a collection of Device Recipes
        Device Recipes Schema
        • {} 3 keys
        • "object"
        • {} 10 keys
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • {} 2 keys
        Device Recipes Example
        • {} 8 keys
        • [] 1 item
        • 1
        • 4
        • 1
        • 0
        • "name"
        • "asc"
        • {} 3 keys
        • "object"
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • "NotFound"
        • "Application was not found"
