Base64: Decode Node
The Base64: Decode Node allows you decode a Base64 string string on the payload, and store that result on the payload for later use. The result will be a binary array by default.
This node is only available in Embedded Workflows. If you would like to decode a Base64 string in any of the other workflow classes, you can do so using the {{decodeBase64}} helper.
Base64: Decode Node
The Base64: Decode Node's configuration has a single section ...
Define the data source and the destination for the result:
  • Encoded String Path: The payload path to the string to decode.
  • Decoded Result Path: The payload path at which to store the result.
  • Output as UTF-8 String: Optionally, you may want the result to be a UTF-8 encoded string instead of a binary array.
In the above example, the workflow will decode the string at the data path and place the results at the working.parsedBase64 path as a string. So, for example, given the following payload:
"data": "TXkgc3RyaW5n",
The payload after execution of the Base64: Decode Node would look like:
"parsedBase64": "My string"
In the case that the provided input is not a valid Base64 string, the workflow will error.
