JSON: Decode Node
The JSON: Decode Node allows a workflow to decode a JSON (JavaScript Object Notation) string on the payload, and store that result on the payload for later use.
JSON: Decode Node
The JSON: Decode Node's configuration is broken up into two sections ...
First, define the JSON string data source and the destination for the result:
  • Encoded String Path: The payload path to the string to decode.
  • Decoded Result Path: The payload path at which to store the result.
Note: It is possible for both paths to be the same, in which case the JSON string will be replaced by the decoded result.
Next, define the error handling behavior. In the case that the provided JSON string fails to parse, there are two possible options for how to handle the error.
  • Error the workflow: Halt the workflow at this node, preventing further execution.
  • Store JSON error at payload path: Configure a payload path at which to store the error.
Note: For Edge Workflows, this option is only available GEA version 1.14.0 or higher. On older versions, the workflow will always halt on errors.
In the above example, the workflow will decode the string at the data path and place the resulting object at the working.parsedJson path. So, for example, given the following payload:
"data": "{\"messageBody\":[12,24],\"name\":\"Trigger52\"}",
The payload after execution of the JSON: Decode Node would look like:
"parsedJson": {
"messageBody": [
12,
24
"name": "Trigger52"
In the case that the provided JSON string fails to parse, there are two possible options. You can either error the workflow, or you can store the error at a path on the payload.
Below is an example of an error stored on the payload:
"data": "notJson",
"jsonError": {
"message": "Invalid JSON source: data",
"type": "JSON_DECODE_NODE_ERROR"
