Storage: Get Value Node
The Storage: Get Value Node allows a workflow to retrieve a value stored in a previous run of the workflow by the Storage: Set Value Node. Stored values can also be viewed and manipulated using the workflow storage tab.
Storage Get Value Node
There are three configuration properties for the Storage: Get Value Node - an identifier, a payload path, and an optional default value.
The identifier is a string template for identifying value to retrieve - and while it can be an arbitrary string, it should match the identifier of a previously stored value - i.e., the identifier used in the configuration of a Storage: Set Value Node.
The payload path defines where the workflow should place the retrieved value on the current payload. The optional default value is only used if there is no value previously stored with the specified identifier - in which case, the specified default value is placed on the payload instead. When defining the default value, you must first choose a “Default Value Type”, which allows for setting the value as a payload path, string template or JSON template.
Storage Get Value Node Example
In the above example, the workflow will fetch the value stored under the identifier storedColor, and will place that value in the current payload at the path data.color. If there is no value stored under storedColor, the workflow will place 0 in data.color instead. So, in the case that the value 12562 was stored under the storedColor identifier and the workflow was executed with the following payload:
  "data": { },
  "applicationName": "Light Wall",
  "triggerType": "deviceId",
  "deviceTags": { },
  "deviceName": "Ranger",
  "globals": { },
  "flowName": "Range To Color"
The payload after the execution of the Storage: Get Value Node would look like:
    "color": 12562
  "deviceTags": { },
  "globals": { },
