List of Workflow Nodes
Below is a list of all workflow nodes available in Losant’s cloud platform, in the Gateway Edge Agent, and in the Embedded Edge Agent. Nodes are broken down by category and can be filtered by their availability for a given workflow class.
To learn more about a node, click its name to view detailed documentation and examples.
Triggers
Amazon SQS Trigger
The Amazon SQS Trigger fires a workflow whenever a Losant integration receives an Amazon Simple Queue Service (SQS) message.Application: Sync Trigger
The Application: Sync Trigger fires a workflow whenever the Gateway Edge Agent receives updated peripherals, global values, or changes to its Edge Compute device configuration.Azure Event Hubs Trigger
The Azure Event Hubs Trigger fires a workflow whenever a Losant integration receives an Azure Event Hubs message.Beckhoff Trigger
The Beckhoff Trigger fires a workflow whenever monitored symbols on a Beckhoff TwinCAT PLC receive new values.Data Table Trigger
The Data Table Trigger fires a workflow whenever a row is added, updated, or removed from a Losant Data Table.Device: Command Trigger
The Device: Command Trigger fires a workflow whenever its Edge Compute or Embedded Device receives a command over the MQTT broker.Device: Connect Trigger
The Device: Connect Trigger fires a workflow whenever one or more devices connect to the Losant Platform.Device: Create Trigger
The Device: Create Trigger fires a workflow whenever a device is created within your application.Device: Disconnect Trigger
The Device: Disconnect Trigger fires a workflow whenever one or more devices disconnect from the Losant Platform.Device: Inactive Trigger
The Device: Inactive Trigger fires a workflow whenever one or more devices do not report state for the configured period of time.Device: Startup Trigger
The Device: Startup Trigger fires a workflow whenever the Gateway Edge Agent starts or restarts.Device: State Trigger
The Device: State Trigger fires a workflow whenever a device reports state to the Losant cloud platform.Direct Trigger
The Direct Trigger fires an Embedded Workflow whenever the "eea_direct_trigger" method is invoked within the Embedded Edge Agent.EEA: Init Trigger
The EEA: Init Trigger fires a workflow whenever the "eea_init" function is called within the Embedded Edge Agent.Email Trigger
The Email Trigger fires a workflow whenever your application receives an email at its address or a subaddress.Endpoint Trigger
The Endpoint Trigger fires a workflow when the selected Experience Endpoint receives an HTTP request.Event Trigger
The Event Trigger fires a workflow whenever an event matching the criteria defined in the trigger's configuration is created or changes state.File Tail Trigger
The File Tail Trigger allows you to monitor and analyze logs and other files on the Gateway Edge Agent's container or host file system.File Trigger
The File Trigger allows you to fire a workflow when a file is created, modified, or deleted from a directory in your Application Files.File Watch Trigger
The File Watch Trigger fires a workflow whenever the file or directory changes are observed on the Gateway Edge Agent.GCP Pub/Sub Trigger
The GCP Pub/Sub Trigger fires a workflow whenever a message is sent to a Losant GCP Pub/Sub integration.HTTP Request Trigger
The HTTP Request Trigger fires a workflow whenever the Gateway Edge Agent receives a request on its local web server.Job: Complete Trigger
The Job: Complete Trigger fires a workflow whenever a Resource Job completes all iterations or is canceled during execution.Job: Iteration Trigger
The Job: Iteration Trigger fires a workflow whenever an iteration of a Resource Job begins.Job: Timeout Trigger
The Job: Iteration Timeout Trigger fires a workflow whenever an iteration of a Resource Job is not acknowledged before the Resource Job’s configured timeout.MQTT Trigger
The MQTT Trigger fires a workflow whenever a message is published to a topic on the Losant MQTT Broker, the Gateway Edge Agent Local Broker, an external broker, or an MQTT integration.Notebook Trigger
The Notebook Trigger fires a workflow whenever the selected Losant Notebook has completed an execution, either successfully or with errors.OPC UA Trigger
The OPC UA Trigger fires a workflow whenever an Edge Compute Device receives a change message on the configured OPC UA monitored node.Particle Trigger
The Particle Trigger fires a workflow whenever an event is received on the Losant Particle integration.Redis Trigger
The Redis Trigger fires a workflow whenever the Edge Compute Device receives a message on the configured Redis Pub/Sub channel.Serial Trigger
The Serial Trigger fires a workflow whenever the Edge Compute Device receives data over a Serial connection.SNMP: Trap Trigger
The SNMP: Trap Trigger fires a workflow whenever the Edge Compute Device receives an SNMP trap message or an SNMP inform request.Timer Trigger
The Timer Trigger fires a workflow on a scheduled interval.UDP Message Trigger
The UDP Message Trigger fires a workflow whenever the Edge Compute Device receives a UDP datagram on the configured port.Virtual Button Trigger
The Virtual Button Trigger fires a workflow when the "virtual button" is pressed.Webhook Trigger
The Webhook Trigger fires a workflow whenever a Losant webhook receives an HTTP request or WebSocket message.WebSocket Trigger
The WebSocket Trigger fires a workflow whenever a Losant WebSocket integration receives a message.Workflow Error Trigger
The Workflow Error Trigger fires a workflow whenever a halting error occurs in a separate workflow execution.
Debug Nodes
Debug Node
The Debug Node prints out the current payload and execution timing info at the point of invocation within a workflow run.Throw Error Node
The Throw Error Node halts a workflow execution, logs the provided error message, and fires any associated Workflow Error Triggers.
Experience Nodes
Authenticate Experience User Node
The Authenticate Experience User Node authenticates an email and password against Experience Users in a Losant application.Device: Verify Node
The Device: Verify Node checks whether a given device is associated with an Experience Group or Experience User in a Losant application.Generate Experience User Token Node
The Generate Experience User Token Node creates a token for an Experience User to make authorized requests against Experience Endpoints.Group: Create Node
The Group: Create Node adds a new Experience Group to a Losant application.Group: Get Node
The Group: Get Node retrieves one or more Experience Groups from a Losant application.Group: Summary Node
The Group: Summary Node retrieves Experience Groups in a hierarchical tree format.Group: Update Node
The Group: Update Node updates an existing Experience Group within a Losant application.Group: Verify Node
The Group: Verify Node checks whether a given Experience User is a member of an Experience Group or any of the group's children.SAML: Login URL Node
The SAML: Login URL Node creates a login URL for a Security Assertion Markup Language 2.0 (SAML) single sign-on (SSO) identity provider.SAML: Verify Node
The SAML: Verify Node verifies and extracts response data from a Security Assertion Markup Language 2.0 (SAML) single sign-on (SSO) identity provider.User: Create Node
The User: Create Node adds a new Experience User to a Losant application.User: Delete Node
The User: Delete Node removes an Experience User from a Losant application.User: Get Node
The User: Get Node retrieves one or more Experience Users from a Losant application.User: Update Node
The User: Update Node updates an existing Experience User within a Losant application.
Logic Nodes
Array Node
The Array Node performs operations against an array-type value on the payload.Base64: Decode Node
The Base64: Decode Node takes a Base64-encoded string and decodes it as a binary array.Base64: Encode Node
The Base64: Encode Node takes a string or binary array and encodes it to a Base64 string.CBOR: Decode Node
The CBOR: Decode Node takes a CBOR-encoded value on the payload and converts it into a JSON object.CBOR: Encode Node
The CBOR: Encode Node converts a JSON object into Concise Binary Object Representation format.Conditional Node
The Conditional Node branches a workflow based on the result of an expression.CSV: Decode Node
The CSV: Decode takes a CSV string and decodes it into an object array.CSV: Encode Node
The CSV: Encode Node takes an object array and encodes it into a CSV string.Date/Time Node
The Date/Time Node allows for parsing and manipulating dates and timestamps.Delay Node
The Delay Node pauses a workflow execution for a short period of time.Fast Fourier Transform Node
The Fast Fourier Transform Node takes an array of data points from one domain and converts it into a frequency representation using a fast Fourier transform algorithm.Function Node
The Function Node allows execution of arbitrary, user-defined JavaScript.Generate ID Node
The Generate ID Node creates IDs in UUID, Object ID, or Nano ID format.Geofence Node
The Geofence Node branches a workflow based on whether a given geographic point is within a defined area.Hash Node
The Hash Node creates a cryptographic hash through a variety of algorithms.HTML/XML Parser Node
The HTML/XML Parser Node takes an HTML or XML document string and parses it into a traversable tree.JSON: Decode Node
The JSON: Decode Node takes a JSON string and parses it into an object.JSON: Encode Node
The JSON: Encode Node takes an object and converts it into a JSON string.JWT: Create Node
The JWT: Create Node generates a JSON Web Token from a JSON payload, optional headers, and a secret.JWT: Decode Node
The JWT: Decode Node takes a JSON Web Token and decodes it to an object.JWT: Verify Node
The JWT: Verify Node branches a workflow based on whether a provided JSON Web Token is valid.Latch Node
The Latch Node allows for easy "one-time" branching of a workflow, with the ability to reset the branch condition.Loop Node
The Loop Node allows for iterating over values on your payload, or for performing a certain operation a set number of times.Math Node
The Math Node performs expression-based mathematical calculations.Mutate Node
The Mutate Node modifies, moves, copies, or removes values from a workflow payload.Object Node
The Object Node performs operations against objects or arrays on the payload.On Change Node
The On Change Node branches a workflow based on whether a value has changed since previous executions of the workflow.Random Number Node
The Random Number Node generates a random integer within a range of your choosing.Root Mean Square Node
The Root Mean Square Node calculates the root mean square (RMS) of an array of numbers.Rust Function Node
The Rust Function Node allows for execution of user-defined Rust code.String Node
The String Node allows for manipulating string values.Switch Node
The Switch Node branches across many different paths based on matching a switch statement against various case values.Throttle Node
The Throttle Node branches a workflow based on the amount of time that has passed since the last execution of the node.Time Range Node
The Time Range Node branches based on whether a given timestamp is within a provided time range.Validate Payload Node
The Validate Payload Node branches a workflow based on whether a given value validates against a provided JSON schema.
Data Nodes
Access Key: Create Node
The Access Key: Create Node generates a new Access Key for authenticating against the Losant MQTT Broker.Agent Config: Get Node
The Agent Config: Get Node retrieves configuration settings for an instance of the Gateway Edge Agent.Agent Config: Set Node
The Agent Config: Set Node changes configuration settings for an instance of the Gateway Edge Agent.Allen-Bradley: Read Node
The Allen-Bradley: Read Node reads multiple tags from an Allen-Bradley CompactLogix or ControlLogix programmable logic controller (PLC).Allen-Bradley: Write Node
The Allen-Bradley: Write Node writes to multiple tags on an Allen-Bradley CompactLogix or ControlLogix programmable logic controller (PLC).AWS Lambda Node
The AWS: Lambda Node executes an AWS Lambda function and optionally returns the result.AWS S3: Get Node
The AWS S3: Get Node retrieves a file and its metadata from an Amazon S3 bucket.AWS S3: Put Node
The AWS S3: Put Node uploads a file into an Amazon S3 bucket.Azure Blob: Get Node
The Azure Blob: Get Node retrieves a file and its metadata from an Azure Blob Storage container.Azure Blob: Put Node
The Azure Blob: Put Node uploads a file to an Azure Blob Storage container.Azure: Function Node
The Azure: Function Node executes an Azure Function and optionally returns the result.Azure: Table Storage Node
The Azure: Table Storage Node allows you to perform entity operations on an Azure Data Table.BACnet: Read Node
The BACnet: Read Node reads multiple properties across multiple objects from a BACnet device.BACnet: Who-Is Node
The BACnet: Who-Is Node broadcasts a Who-Is message and awaits I-Am replies from BACnet-compatible devices on a network.BACnet: Write Node
The BACnet: Write Node writes multiple properties in multiple objects on a BACnet device.Beckhoff: Read Node
The Beckhoff: Read Node reads multiple symbol values from a Beckhoff TwinCAT PLC.Beckhoff: Write Node
The Beckhoff: Write Node allows for writing values to one or more symbols on a Beckhoff TwinCAT PLC.Data: Gauge Query Node
The Data: Gauge Query Node retrieves aggregate state data for one or more attributes across one or more devices.Data: Time Series Node
The Data: Time Series Node retrieves state data across a time period for one or more attributes across one or more devices.Device: Create Node
The Device: Create Node adds a new device to a Losant application.Device: Delete Node
The Device: Delete Node removes one or more devices from a Losant application.Device: Get Node
The Device: Get Node retrieves one or more devices from a Losant application.Device: Update Node
The Device: Update Node updates an existing device within a Losant application.Event: Create Node
The Event: Create Node generates a new event within a Losant application.Event: Delete Node
The Event: Delete Node removes one or more events from a Losant application.Event: Get Node
The Event: Get Node retrieves one or more events from a Losant application.Event: Update Node
The Event: Update Node updates one or more existing events within a Losant application.File: Create Node
The File: Create Node creates a file within a Losant application's files.File: Read Node
The File: Read Node retrieves a file from disk on an Edge Compute Device.File: Write Node
The File: Write Node writes a file to disk on an Edge Compute Device.FTP: Get Node
The FTP: Get Node retrieves a file from an FTP or SFTP server.FTP: Put Node
The FTP: Put Node uploads a file to an FTP or SFTP server.GCP Storage: Get Node
The GCP Storage: Get Node retrieves a file and its metadata from a Google Cloud Storage bucket.GCP Storage: Put Node
The GCP Storage: Put Node uploads a file to a Google Cloud Storage bucket.GCP: BigQuery Node
The GCP: BigQuery Node makes requests to a Google BigQuery table.GCP: Function Node
The GCP: Function Node executes a Google Cloud Function and optionally returns a result.GCP: ML Node
The GCP: ML Node sends data to Google ML and retrieves predictions based on models in that service.HTTP Node
The HTTP Node makes arbitrary HTTP requests to third-party services.Loggly: Write Node
The Loggly: Write Node sends one or more messages to SolarWinds LogglyLosant API Node
The Losant API Node makes application-scoped requests against the Losant API.Modbus: Read Node
The Modbus: Read Node reads multiple registers from Modbus-enabled PLCs.Modbus: Write Node
The Modbus: Write Node writes to multiple registers on Modbus-enabled PLCs.MongoDB Node
The MongoDB Node runs queries against a MongoDB database.OPC UA: Browse Node
The OPC UA: Browse Node allows for browsing node folders on an OPC UA Server.OPC UA: Call Node
The OPC UA: Call Node calls a method on an object within an OPC UA Server and connected programmable logic controller (PLC).OPC UA: Read Node
The OPC UA: Read Node retrieves multiple node values from an OPC UA Server and connected programmable logic controller (PLC).OPC UA: Write Node
The OPC UA: Write Node writes multiple node values to an OPC UA Server and connected programmable logic controller (PLC).Peripheral: Get Node
The Peripheral: Get Node retrieves one or more of an Edge Compute Device's associated Peripheral Devices.Redis Node
The Redis Node queries or updates values in a Redis database.Registered Function Node
The Registered Function Node invokes a registered function defined on an Embedded Device.Run Executable Node
The Run Executable Node runs a script or process locally on an Edge Compute Device.Salesforce Cases Node
The Salesforce Cases Node accesses the Salesforce Service Cloud to create, read, update, or delete cases in their CRM platform.Serial: Write Node
The Serial: Write Node writes values to a specified serial port.ServiceNow Node
The ServiceNow Node create, updates, and retrieves records from tables in the ServiceNow platform.Siemens S7: Read Node
The Siemens S7: Read Node allows you to read one or more values from a PLC that supports the Siemens S7 protocol.Siemens S7: Write Node
The Siemens S7: Write Node allows you to write one or more values to a PLC that supports the Siemens S7 protocol.SNMP: Get Subtree Node
The SNMP: Get Subtree Node reads values beneath a root OID on an SNMP device.SNMP: Read Node
The SNMP: Read Node reads values from multiple OIDs on an SNMP device.SNMP: Write Node
The SNMP: Write Node writes values to one or more OIDs on an SNMP device.SQL Node
The SQL Node queries or updates values in an SQL database.Storage: Get Value Node
The Storage: Get Value Node retrieves a value set by a Storage: Set Value Node in a previous workflow execution.Storage: Set Value Node
The Storage: Set Value Node stores a value for use in a subsequent workflow execution.Table: Delete Rows Node
The Table: Delete Rows Node deletes one or more rows from a Losant Data Table.Table: Get Rows Node
The Data Table: Get Rows Node retrieves one or more rows from a Losant Data Table.Table: Insert Rows Node
The Data Table: Insert Row Node adds one or more new rows to a Losant Data Table.Table: Update Row Node
The Table: Update Row Node updates an existing row in a Losant Data Table.TensorFlow: Predict Node
The TensorFlow: Predict Node makes predictions against a pretrained TensorFlow model that has been loaded onto an Edge Compute Device.
Output Nodes
Amazon SQS Node
The Amazon SQS Node publishes a message to an Amazon SQS queue.Azure Event Hubs Node
The Azure Event Hubs Node publishes a message to an Azure Event Hub.Device: Command Node
The Device: Command Node sends a command to one or more devices connected to the Losant MQTT Broker.Device: State Node
The Device: State Node records telemetry data as attributes for a device.Email Node
The Email Node sends an email to one or more users through Losant's provided email delivery.Endpoint: Reply Node
The Endpoint Reply Node sends a response to an Experience Endpoint HTTP request.GCP Pub/Sub Node
The GCP (Google Cloud Platform) Pub/Sub Node publishes a message to a Google Pub/Sub topic.HTTP Node
The HTTP Node makes arbitrary HTTP requests to third-party services.HTTP Response Node
The HTTP Response Node sends a response to an HTTP request received by an Edge Compute Device's local web server.Job: Acknowledge Node
The Job: Acknowledge Node marks an iteration of a Resource Job as a success or failure.Job: Execute Node
The Job: Execute Node requests an execution of one of your application’s Resource Jobs.Mailgun Node
The Mailgun Node sends emails through a given Mailgun account.MQTT Node
The MQTT Node publishes a message to the Losant MQTT Broker, the Gateway Edge Agent Local Broker, an external broker, or an MQTT integration.Notebook: Execute Node
The Notebook: Execute Node initiates an execution of a Losant Notebook.Particle Call Node
The Particle Call Node invokes a remote function on a device within Particle.SendGrid Node
The SendGrid Node sends emails through a given SendGrid account.Slack Node
The Slack Node sends messages to a given channel within a Slack workspace.SMS Node
The SMS Node sends an SMS message through Losant's provided SMS delivery service.Twilio Node
The Twilio Node sends SMS messages using the configured Twilio account.UDP Send Node
The UDP Send Node sends a UDP datagram to a given address and port.Webhook: Reply Node
The Webhook: Reply Node sends a response to an HTTP request received by a Losant Webhook.WebSocket Message Node
The WebSocket Message Node publishes a message to a WebSocket integration.WhatsApp Node
The WhatsApp Node allows you to send messages using your WhatsApp Business account.Workflow Trigger Node
The Workflow Trigger Node invokes another workflow execution with a custom payload.
