JSON Decode Node
The JSON Decode Node allows a workflow to decode a JSON string into an object on the payload.
JSON Decode Node
There are two configuration properties for the JSON Decode Node - the payload path to the string to decode, and the payload path for where to store the resulting decoded object. Both paths are allowed to be the same, in which case the JSON string will be replaced by the decoded object.
JSON Decode Node Config
In the above example, the workflow will decode the string at the container.jsonString path and place the resulting object at the container.jsonObject path. So, for example, given the following payload:
  "container": {
    "jsonString": "{\"messageBody\":[12,24],\"name\":\"Trigger52\"}"
The payload after execution of the JSON Decode Node would look like:
  "container": {
    "jsonString": "{\"messageBody\":[12,24],\"name\":\"Trigger52\"}",
    "jsonObject": {
      "messageBody": [
        12,
        24
      "name": "Trigger52"
