JWT: Decode
The JWT: Decode Node allows a workflow to decode a JSON Web Token on the payload.
JWT Decode Node
The JWT: Decode Node requires a token template and a result path. There is one optional configuration which is a checkbox called Complete Payload, Headers and Signature. If this is checked and the JWT successfully decoded, the result will include the JWT’s signature, decoded payload and headers.
JWT Decode Configuration
Example Result Complete Payload, Headers and Signature turned off:
"jwtPayload": {
  "iss":"issuer.com"
  "scope":"https://www.googleapis.com/auth/cloud-platform"
  "aud":"https://www.googleapis.com/oauth2/v4/token"
  "iat":1509374356
  "exp":1509460756
Example Result Complete Payload, Headers and Signature turned on:
"jwtPayload": {
  "header": {
    "alg": "RS256",
    "typ": "JWT"
  "payload": {
    "iss":"issuer.com"
    "iat":1509374356
    "exp":1509460756
  "signature": "aSinGatuR_e"
Outputs
The JWT: Decode Node has one output field. The Destination Path field takes a payload path. If successfully decoded, the JWT decode result will be placed on the payload at this path, otherwise it will be an error object.
