JWT: Verify
The JWT: Verify Node allows a workflow to verify that a JSON Web Token on the payload is valid. This node will branch based upon the conditional output, like the Conditional Node.
JWT Verify Node
The JWT Verify Node requires two fields, the Token Template and the Secret Template. The Token Template is the JSON Web Token to be verified. The Secret Template is the secret key used to sign the JWT when created. If the JWT is valid, the payload will be pushed down the right side output, if it is not valid it will travel down the left. There are two optional input fields. One is the Issuer Template which validates the issuer against the token. The second is the Error Path. The Error Path field takes a payload path, and if the JWT is not valid an error will be placed at this path on the payload.
JWT Verify Node Config
