Application
Device: Inactive Trigger
The Device: Inactive Trigger will fire a workflow whenever one or more devices do not report state for the configured period of time.
Device Inactive Trigger
There are two parts to configuring a Device: Inactive Trigger - the devices to trigger on, and the amount of time a device should be inactive before triggering. The trigger can be configured with one or more specific devices, or a selection of tags (or both). See the device query documentation for more info about how ID and tag matching works. The inactivity time can be configured as seconds, minutes, hours, or days, and can be any duration between 1 second and 1 year. When a device that matches anything in the selection does not report state for the configured period of time, the workflow will trigger.
Device Inactive Trigger Config
In the above example, the workflow will be triggered whenever any device with the floor tag set to 2 or the specific devices FM00000001A or FM00000002A do not report state for 2 hours.
The payload will include the date of the last state report in the data field, as well as the duration of inactivity. In the general case, a device inactive workflow payload will look like the following:
  "time": <time of the event>,
    "lastActivity": <time of last state report>,
    "inactivitySeconds": <duration of inactivity>
  "triggerId": <id of the triggering device>,
  "triggerType": "deviceIdInactivity",
  "deviceTags": {<any tags for the device>},
  "deviceName": <the device name>,
  "globals": <object of workflow globals>
For the example workflow above, a specific payload for a triggered workflow might look like this:
    "lastActivity": Fri Feb 19 2016 16:26:00 GMT-0500 (EST),
    "inactivitySeconds": 7200
  "applicationName": "Embree",
  "triggerType": "deviceId",
  "deviceTags": {
    "floor": ["2"],
    "location": ["warehouse1"]
  "flowName": "Report Failure Warning",
  "globals": {}
Notes
The Device: Inactive Trigger starts monitoring from scratch when added or changed. This means that for the trigger to fire, one state message must arrive from the device after the trigger is configured, and then inactivity starts counting from that message (or subsequent messages) onward. If a device never reports state after the trigger is configured, the trigger will never fire for that device.
In addition, the timestamp of state payload arrival at Losant is used for calculating inactivity. This means that a device that sends a state payload now whose data is for 1 day ago will be counted as active now, not retroactively active 1 day ago.
